0 members (),
128
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 27 New Guy | | New Guy Joined: Jan 2009 Posts: 27 | I am in the process of converting my 65 GMC Single MC to a dual MC. I will be using a 68 GMC dual MC because it mounts perfectly. I have been reading through the forums and still have a few questions. I plan on leaving the four wheel drums due to the fact that i will be driving the truck less than 2K miles a year. In some forums people recommend a proportioning valve and in others some recommend a distribution block. What is the best way to go for my setup? And what is the difference between the two? Thanks for any information. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | 68 gmc was 4 wheel drum. You are already using the 68 MC, use whatever else the 68 gmc used. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If he originally had a single circuit MC then the question is what new valve or distribution block if any should he now use with a dual circuit MC?
I say find a proportioning valve from another GM truck with drum/drum brakes and use it with your new dual circuit MC. What did the 68 GMC use (your MC donor)?
But I don't have any technical reasons why or what you should do.
Grigg | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | you should be able to add the extra line and go. on a upgrade to dual mc from single and both are for drum setup the 68' mc should have built in portioning valve | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | I agree with 10 micron. You don't need a proportioning valve with the drum/drum set up. | | | | | Joined: Jan 2009 Posts: 27 New Guy | | New Guy Joined: Jan 2009 Posts: 27 | After checking around, I found out that I need a distribution block to keep the rear brakes from locking up. (The Dual MC does not automatically do it). All of the parts houses around Nashville told me to go to the dealer to get one. Fortunately I found a fellow parting out a 68 gmc, and he was willing to part with the needed piece. Now to plumb in new lines, and I will be back on the road again!! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I still think you didn't need it. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Since you found the "part" on a '68, I'd say go with what Chevy did. My books on the '68 don't show it, so are you it is not just a splitter? The books show a splitter on the front cross member.
best wishes,
Les | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Just a thought.......unless you're putting your truck back into showroom stock condition, where authenticity seems to over-ride current technology, why not add a relatively simple little device that helps you control your brake bias?
Having tried the "everything new but stock" configuration with my trucks brakes, I soon discovered that "anticipating stops and laying back" were just prolonging the inevitable. Even at their very best, a panic stop was going to require some major pressure on the pedal and room to control the inevitable rear wheel lockup. Back in the day, when everyone was running drum brakes and traffic was a whole lot lighter, you were on a more level playing field in relationship to bringing the beasts to a halt. But with todays upgraded braking technology on every vehicle, it became apparent that if I was interested in having a safe driver I'd better make some upgrades.
Now I'm not advocating that every Bolt be shod with discs....if you're putzing along on country roads at stock truck speeds and focused on what you're doing you'll probably be okay. However, it only takes one panic stop that wipes out an $80K Beemer to ruin your day. So to me, maximizing your braking POTENTIAL is paramount whether it be drum/drum, disc/drum or disc/disc.
I'm a FIRM believer in using an ADJUSTABLE proportioning valve in all of the options above and also residual valves where applicable. Drum/drum masters are "supposed" to have built-in valves but who knows for sure on a repop? Any issues I've encountered with setting up an upgraded brake system, have come from trying to use a generic proportioning valve. Especially those supplied in the so-called upgrade kits. Incorporating a $40.00 adjustable proportioning valve in even your drum/drum brake system is going to let you better CONTROL rear wheel lockup. Being the obsessive compulsive person I am (my own admission) I extend the adjustment knob up through the floorboard so I can fine-tune the brake bias according to my load and the road conditions. My own take on ABS. (sorta)
When you're upgrading your brakes with the intention of driving your truck on the modern highway, I'd seriously consider adding a relatively inexpensive adjustable proportioning valve instead of a junkyard proportioning/metering valve. Once you get it dialed in you'll enjoy even more, putting your "Bolt" out on the road.
Dave
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Are there any "approved" adjustable proportioning valves? I used one on a truck with disc front and rear, and it worked fine but technically was for "race only" or something like that, wasn't supposed to be legal on the road. Actually once I got it adjusted the first time I never had a need or desire to play with it...
I've also used a "junkyard proportioning valve", a GM one from a vehicle with the same disc brakes front and rear as I have, again no problems, and I'd do it again without a second thought.
And the first time I re-did/upgraded a brake system I used a "generic" proportioning valve that looked just like a GM one, and also worked just fine but cost more that I think it is worth.
What is the great advantage to an adjustable one over the proper factory one or a suitable one form a junk yard?
Grigg | | |
