7 members (Danielbolt, Gdads51, SmalltownTRKGuy, Charles in CA, Bill Hanlon, Peggy M, 1 invisible),
90
Mod | | | Forums66 Topics128,092 Posts1,056,455 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Here's what I have: 69 Pickup with 71 front end, disc brakes.
My problem: the new master cylinder i just put on leaks around the lid. (everything is new)
What I want to do: Use a later model (about 1990) master cylinder because it has a plastic reservoir that should not leak, plus it will look trick.
Any of you guys have any input? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Plastic parts on a real truck? Why not return the new one that leaks and tell them it's not what you paid for. You paid for one that doesn't leak. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | well, don't want to take another chance with a poorly machined part. | | |
