2 members (Materman, 1 invisible),
111
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | I found some fenders from a big bolt Advance Design GMC, will they work on my 47 Chevrolet or are they different?
If it's old and rusted out.... Well it's probably mine. [http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url] 1978 Dodge W200/M880 2002 Dodge Ram 2500 Cummins Diesel Photobucket Pix | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Depending on if your truck is an Advance Design type GMC or not, if it it an AD design yes they will bolt on. Then the other problem would be IF they are 1.5 ton or larger, the fenders & hood from those trucks are larger, wider & longer then the 1/2 ton to 1 ton trucks...Joe
| | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | Joe, The fenders are coming off a 47-50 2 ton GMC, I'm wanting to put them on My 47 Chevy 2 ton, just need to know if everything will fit,
If it's old and rusted out.... Well it's probably mine. [http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url] 1978 Dodge W200/M880 2002 Dodge Ram 2500 Cummins Diesel Photobucket Pix | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | IF your chevy is an AD style truck then yes they will fit BUT you have to use everything that has to do w/the front sheet metal. The hood, fenders, inner fender wells, radiator core support, "EVERTHING" has to be used...Joe | | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | I'm not sure if I'm understanding right. What I'm getting out of it is that if I use the fenders I can't use the grill, hood or other chevrolet parts like the hood latch pan, and would have to use the GMC hood, grill, inner fenders and latch pan. My truck is an advance design Chevrolet loadmaster 2 ton 6400 model, I'm just trying to make sure I've got it right. Thanks Kevin
If it's old and rusted out.... Well it's probably mine. [http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url] 1978 Dodge W200/M880 2002 Dodge Ram 2500 Cummins Diesel Photobucket Pix | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Ya know some times I just brain dead  .... After rereading your post I see you want to use "just" the fenders. The simple answer to that is still "YES".. Sorry for the confusion on my part  ...Joe | | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | It happens man, I appreciate the info, Kevin
