4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#564940 08/14/2009 5:50 AM
Apprentice
Apprentice
I found some fenders from a big bolt Advance Design GMC, will they work on my 47 Chevrolet or are they different?
If it's old and rusted out.... Well it's probably mine.
[http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url]
1978 Dodge W200/M880
2002 Dodge Ram 2500 Cummins Diesel
Photobucket Pix
Kissfan113 #564968 08/14/2009 1:30 PM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Depending on if your truck is an Advance Design type GMC or not, if it it an AD design yes they will bolt on. Then the other problem would be IF they are 1.5 ton or larger, the fenders & hood from those trucks are larger, wider & longer then the 1/2 ton to 1 ton trucks...Joe
#564974 08/14/2009 1:55 PM
Apprentice
Apprentice
Joe, The fenders are coming off a 47-50 2 ton GMC, I'm wanting to put them on My 47 Chevy 2 ton, just need to know if everything will fit,
Photobucket Pix
Kissfan113 #564979 08/14/2009 2:23 PM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
IF your chevy is an AD style truck then yes they will fit BUT you have to use everything that has to do w/the front sheet metal. The hood, fenders, inner fender wells, radiator core support, "EVERTHING" has to be used...Joe
#565192 08/15/2009 3:00 AM
Apprentice
Apprentice
I'm not sure if I'm understanding right. What I'm getting out of it is that if I use the fenders I can't use the grill, hood or other chevrolet parts like the hood latch pan, and would have to use the GMC hood, grill, inner fenders and latch pan. My truck is an advance design Chevrolet loadmaster 2 ton 6400 model, I'm just trying to make sure I've got it right.
Photobucket Pix
Kissfan113 #565222 08/15/2009 3:52 AM
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Ya know some times I just brain dead dang ....
After rereading your post I see you want to use "just" the fenders. The simple answer to that is still "YES"..
Sorry for the confusion on my part ohwell not me ...Joe
#565240 08/15/2009 4:48 AM
Apprentice
Apprentice
It happens man, I appreciate the info,
Photobucket Pix
