| | | Forums66 Topics128,113 Posts1,056,277 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56511 02/14/2006 12:41 AM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Ok here's my problem with my 56 stepside... my right rear tire is rubbing up against the inner well... when I look at the rear tires, it looks like the right is closer to the well then the left... any thoughts on what I should check??
Thanks! | | |
#56512 02/14/2006 1:06 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | First thought: Are tires the same size? Are the wheels the same? Sounds dumb, but had that problem with mix-and-match wheels on a util. trailer. Then: measure the distance from backing plates to spring perches on both sides. Then: check if the box is centered on the frame.
I suppose if the axle slipped back on the leaf spring on one side, it could rub on one side.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#56513 02/14/2006 5:16 AM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | Larry I guess I am on the same track with Highflyer. What has changed recently? Hit any big pot holes lately? Swerve hard to avoid something? If it isn't two different tires (tire rotation) Then I would suppect that the axle has shifted. Looking forward to hearing what it really is. good luck
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#56514 02/14/2006 6:00 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Larry Bear,
As Highflyer said, this might sound dumb..maybe the rear end it where it's suppose to be, could the bed have shifted.
Stuart | | |
#56515 02/14/2006 12:55 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Thanks guys...
Tires are the same and I haven't hit anything... other then the normal here in New England!
How does the bed shift?? I mean, if it's bolted to the frame properly then how would it be out of alignment?
I'm at the garage this evening (to finish replacing the head) so I'm going to do a couple of things:
1) I haven't replaced the bedwood yet, so I'll pull up the temp plywood in place so I can get a better topside visual. 2) Do some measuring of the rear end to make sure that's not out of alignment....
Make sense?? Anything else I should scope out?
Thanks for your advice! | | |
#56517 02/15/2006 2:25 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | TooMany: I agree. Saw a truck on Portage Ave in Winnipeg once. Pulled over to the curb, but his left rear was almost in the next lane. Strangest thing I've seen in a LONG time! I guess either the bearings or the C-clips on the axle ends broke.
#56518 02/15/2006 2:14 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Thanks for all the advice guys.
I think the problem I've been having is that the bed wood is rotted so the bolts attaching the bed to frame are a bit loosy goosy. I ground off the heads last night and pulled the bolts off. Will put new bolts in temporarily until I get a new bed underway.
I'm going to move this thread over to beds for more info.... | | |
