5 members (Gdads51, TUTS 59, 55shaker, MikeStone1953, Wally / Montana), 138 guests, and 1 robot.
Topics128,109
Posts1,056,258
Members48,437
#56511 02/14/2006 12:41 AM
Ok here's my problem with my 56 stepside... my right rear tire is rubbing up against the inner well... when I look at the rear tires, it looks like the right is closer to the well then the left... any thoughts on what I should check??
Thanks!
Larry Bear
55.5 Chevy 3100 Panel
#56512 02/14/2006 1:06 AM
First thought: Are tires the same size? Are the wheels the same? Sounds dumb, but had that problem with mix-and-match wheels on a util. trailer.
Then: measure the distance from backing plates to spring perches on both sides.
Then: check if the box is centered on the frame.
I suppose if the axle slipped back on the leaf spring on one side, it could rub on one side.
#56513 02/14/2006 5:16 AM
Larry I guess I am on the same track with Highflyer. What has changed recently? Hit any big pot holes lately? Swerve hard to avoid something? If it isn't two different tires (tire rotation) Then I would suppect that the axle has shifted. Looking forward to hearing what it really is.
good luck
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#56514 02/14/2006 6:00 AM
Larry Bear,
As Highflyer said, this might sound dumb..maybe the rear end it where it's suppose to be, could the bed have shifted.
Stuart
#56515 02/14/2006 12:55 PM
Thanks guys...
Tires are the same and I haven't hit anything... other then the normal here in New England!
How does the bed shift?? I mean, if it's bolted to the frame properly then how would it be out of alignment?
I'm at the garage this evening (to finish replacing the head) so I'm going to do a couple of things:
1) I haven't replaced the bedwood yet, so I'll pull up the temp plywood in place so I can get a better topside visual.
2) Do some measuring of the rear end to make sure that's not out of alignment....
Make sense?? Anything else I should scope out?
Thanks for your advice!
Larry Bear
#56517 02/15/2006 2:25 AM
TooMany: I agree. Saw a truck on Portage Ave in Winnipeg once. Pulled over to the curb, but his left rear was almost in the next lane. Strangest thing I've seen in a LONG time! I guess either the bearings or the C-clips on the axle ends broke.
#56518 02/15/2006 2:14 PM
Thanks for all the advice guys.
I think the problem I've been having is that the bed wood is rotted so the bolts attaching the bed to frame are a bit loosy goosy. I ground off the heads last night and pulled the bolts off. Will put new bolts in temporarily until I get a new bed underway.
I'm going to move this thread over to beds for more info....
Larry Bear
