| | | Forums66 Topics128,156 Posts1,057,021 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 8 New Guy | | New Guy Joined: Jul 2009 Posts: 8 | Hello, I am the member who asked on 7-26 if I could remove and replace a piston by dropping the oil pan. '57 261 L6 engine. From the responses I removed the oil pan and the head and found a problem piston. It has taken me a while, but I have a new piston. I have been using the old car online manuals for torque values and instructions, but a value is not listed for the pinch bolt. Does anyone have a value. Thanks, you have already been a great help, I can't wait to get the truck going again. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Johnfog, this question came up very recently, I tried to look up the spec., but I couldn't find it either, so I suggested 25 lbs. ft. of torque. As the manual only talks about tightening this bolt with hand tools, I felt this torque would be more than adequate, hope that helps. | | |
