0 members (),
256
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 6 New Guy | | New Guy Joined: Aug 2009 Posts: 6 | I've just acquired a Chevy truck and am looking for some info based on the numbers from the plate. They are:
Engine Number - T19335 Model - 1543 VIN - 61543611286
I was hoping some one may know what these mean. I was told that it is a 1958 6 cyl 2 ton. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage sinefire, there's lots of Canucks here, one will have the model ID - I'm not sure on that part, it's definitely a big bolt, over 1T, and I think "cab and chassis" from the factory .... the first number of the vin indicates it's a '56, or at least the tag is from a '56 .... if it has the single headlights it's 55-7. 58 & 9 have dual headlights
Bill | | | | | Joined: May 2008 Posts: 210 Shop Shark | | Shop Shark Joined: May 2008 Posts: 210 | 6 -year 1956 1543 - Model Cab with chassis 2 ton 160" wheel base 611286 - identifies the particular truck
What else do you need to know? I assume this is a Mapleleaf truck. | | | | | Joined: May 2008 Posts: 210 Shop Shark | | Shop Shark Joined: May 2008 Posts: 210 | Do you have a picture of it. That will help out a lot. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | That sounds like a terrible truck. Tell you what, you bring it out here, and I'll see to it that its "taken care of".
Can't wait for pics! | | | | | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | 46HalfTon is right!
As he indicated, that's what those numbers mean.
I'm pretty sure though, that with those numbers, that is a Chevy truck.
Chev's model ID's started with '15'---Mapleleaf's with '16'---GMC's with '91'.
| | | | | Joined: Aug 2009 Posts: 6 New Guy | | New Guy Joined: Aug 2009 Posts: 6 | Thanks a bunch for the info. It helps a lot.
Pics are on the way. Last night I changed out the burnt generator for an alternator and now we're running pretty good. I'm lucky to have found a couple of parts trucks near by as well.
| | | | | Joined: Aug 2009 Posts: 6 New Guy | | New Guy Joined: Aug 2009 Posts: 6 | I do have one more question...
What size engine would this truck have? I'm guessing 235. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, 235 if it was an original 6
Bill | | | | | Joined: Aug 2009 Posts: 6 New Guy | | New Guy Joined: Aug 2009 Posts: 6 | The 235 doesn't seem to have much acceleration power in 3rd and 4th. Could this be because of the small engine vs. big truck? Really should I be expecting much anyway? | | | | | Joined: Aug 2009 Posts: 6 New Guy | | New Guy Joined: Aug 2009 Posts: 6 | That sounds like a terrible truck. Tell you what, you bring it out here, and I'll see to it that its "taken care of".
Can't wait for pics! Its * if thats what you mean by terrible. It's been sitting for 12 or more years and looks rough but running now. Pictures by monday.
| | | | | Joined: Aug 2009 Posts: 3 New Guy | | New Guy Joined: Aug 2009 Posts: 3 | Where do you guys find out your info? I got a maple leaf 3 ton i'd like to check out. Edit: Found a website http://www.oldgmctrucks.com
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey Guy, welcome to the garage .... the place we find our info  just start a thread in either the truck talk or the great white north forum, with something about 'maple leaf' in the title and someone will pony up eventually, there's a couple here with quite a bit of info about them - really re-badged GMC's sinefire - the 235 isn't gonna have a lot of high end, the power is in the mid and low ranges, which is why the big trucks are geared as they are, don't expect to be flyin low on the highway  Bill | | | | | Joined: May 2008 Posts: 210 Shop Shark | | Shop Shark Joined: May 2008 Posts: 210 | I would have thunk that the engine would have been a 261, not a 235? I was under the impression that small 46's had the 216 and bigger had the 261. Red58 - My Mapleleaf looked like a rebadged Chevrolet, not GMC. it had the Chevy Grill on it but the engine valve cover had GMC punched into it. Guy, I used to have a 1941 3 ton. Check my Flickr site. You are in the right place for info. I have not found many sites about the Canadian trucks. http://www.brads41-46chevys.com/ has some info about them. Otherwise get options package from GM. www.vintagevehicleservices.com It is well worth the money! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | sinefire's truck is a 56 .... my understanding was Mapleleafs [just a 'model' by the 50's] were on GMC chassis .... but yes, the big'uns may have had 261's out of a Chevy plant, some casting numbers should tell
Bill | | | | | Joined: May 2008 Posts: 210 Shop Shark | | Shop Shark Joined: May 2008 Posts: 210 | Oh right. I fell and hit my head on the weekend. That's my excuse. | | |
