1 members (Hotrod Lincoln),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,677 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | I put the generator in a vise, hook up a volt meter to the "A" marked bolt connection on the generator (I'm guessin thats the Generator connection to the voltage regulator on the truck) and the other volt meter lead to Ground on the generator, and spin the generator with a drill.
Anybody done this before? If you have what voltage did your meter read?
Tia and Adios, Kip
Write On The Cross At The Head Of My Grave To Whiskey And Women Here Lies A Poor Slave
| | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Ok then, How do I bench test a generator?
Tia and Adios, Kip
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | when the local shop has done it for me they put it on a test fixture that drives it with an electric motor and has a couple meters attached ... not sure exactly what's required, but maybe you have an auto electric place around that could check it if ya ask real nice?  Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The most basic test is to ground the field and apply a good healthy 6v supply to the armature. If it turns like a motor then it is in working condition. I also turned mine with an electric motor and belt. With the field grounded and no load applied it produced 20 v. You don't want to hold it there very long. | | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 |
| | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Ok Truckernix, I'm going to hook up my 6 Volt battery charger as the source for "the basic" test you described above and see what happends.
Tia and Adios, Kip
| | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | The most basic test is to ground the field and apply a good healthy 6v supply to the armature. If it turns like a motor then it is in working condition. I also turned mine with an electric motor and belt. With the field grounded and no load applied it produced 20 v. You don't want to hold it there very long. Ok I did the "basic test" and both generators I have turned good. BUT spinning the armature with a drill as per the 2nd test you mentioned is only giving me about .25 Volts out (yes the meter is on the right scale) on both of the generators. Is the drill spinning the armature fast enough (3Amp Approx. 1200 RPM drill)? What am I doing wrong??? Thanks Truckernix! Adios, Kip
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Kip, did you ground the field when you did the spin test? That is really the only way it will produce anything. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Not sure if this applies here but if you turn the generator into a motor might it need repolarized to be a generator again, at least efficiently? If not, it might help anyway.....  | | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Go back after it again sometime today. Will post later. Looks like a busy weekend.
Thanks Guys!
Kip
| | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Ok, One of the generators gives me about 9 Volts out, the other about 1 Volt out. Doin the 2nd test Truckernix explained. I know Not to spin it too long.
Am I getting there?
Tia and Adios, Kip
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would think that a generator that will motor should produce a lot more than 9 volts when spun up, with the field connect to ground. Are these Chevy generators? Ford uses a different setup. | | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Yep they are Delcos. One has the brushes build into the end cover and is really long. The other is real short and has the brushes built into the generator housing. They both have the little metal Delco tag.
I've been grounding the field connection. I'll try one more time.
Should I apply some sort of voltage somewhere to induce (excite) some sort of field first?
Thanks Truckernix!
Adios, Kip
| | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Hey Truckernix, I got soccer all weekend but will try tackling the generator again in between.
Last night I did try and get better than 8/9 Volts out of the generator but no. And yes I've done Exactly what you told me With Good connections to everything. Also I searched the net till 2AM things like: "spinning AC Delco-Remy 6 Volt generators with a drill output voltage", HA! I found kind of a result a few times. But they were basically Asking the question about how it's done And what the output voltage on the meter should be, No answers though just long explainations on other tests and the motoring one. So I'm still going with your approx. 20.
And Truckernics Thank You VERY Much for helping me with this! I always knew you were a cool cookie.
Adios, Kip
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Kip, when I was playing with my generator, I decided to hook it up to a load. I hooked it up to a six volt headlight. With the grounded field and driving it with an electric motor, the headlight went brilliant white and went off like a flash bulb! | | | | | Joined: Feb 2000 Posts: 177 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 177 | Ok I went to an Auto Electric Shop this morning with the Voltage Regulator and Generator off the truck. The guy there said he could only check them on the truck. I explained the two test I have done with the results. He told me it sounds like the Generator is good and that I am not spinning it fast enough with a drill to get 20 Volts out of it. But if it's "motoring" And I'm getting 8-9 Volts out of it with a 1200 RPM drill applied directly to the armature shaft that the generator is good.
I don't know I still need to check the Voltage Regulator. Maybe I'll put everything Back on the truck and test it from there Or try and find another guy who can test the Regulator off the truck.
On top of all this I have regular life to deal with just like everybody else.
Adios, Kip
