0 members (),
100
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well about every wheel bearing dust cover I’ve ever run into looks like it was put on with a three pound ball peen hammer, using the ball end at that. Soooooo, I decided to whip up a little AD 3100/3600 dust cover driver the other morning. Now I got another tool that I’ll use once every four or five years, that is if I remember that I have it in the box! The tool for the man who has everything: http://www.pbase.com/dennygraham/image/116021940 In action: http://www.pbase.com/dennygraham/image/116021962 Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Denny has a lathe and likes to play with it, LOL, Scott | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | But I gotta say Scott, it does work reeeeeal nice. I've seen them at some of the vendors but I would never spend the money for one. I just so happened to have a piece of aluminum tubing with a 3" od. and a 2" id. The rest is just plane boring. Denny Graham Sandwich, IL
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You know, if you just so happened to have some extra material...............
haha, Scott | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now don't ya have to many tools that you only use once every now an then in your toolbox alreasy Scott? I'd liken this to the egg slicer that Lenny is hawking on the T&V, use it once and then reach for the hammer the next time. I have had a lot of fun making some of the other special tooling to fix up the truck. Now I'd be able to use a lot of that more than once if I started restoring trucks as a sideline. But I have enough sidelines tugging at me right now. Have a good weekend buddy, Denny Graham Sandwich, IL
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | I like that Denny. Your right every dust cap I run across has been mutilated with a hammer. Did you buy a new Rubber Mallet for your installation picture? Looks like it has never been used before. LOL Keep up the good work. Cleon | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | So, do you have a dust cap taker-offer? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Nope had it for a year or so, only use the white one when I want to be very gentle with something Cleon. Taker-offer? Sure, a Red Devil putty knife, a wide blade screwdriver and that soft hammer. DG
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | So, do you have a dust cap taker-offer? I do!
Bruce | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | | | |
