Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#564303 08/12/2009 7:05 AM
First I just want to say hello to everyone. Been an extrmely long time sense I been around these part.
So I have had the fortain to pick up a 52 chevy 4100. only 3 now 4 original owners the first being Greenfield Irrigation Project in Fairfield, Montana. next 2 brother and now me. Ill have to tell that story later.
The truck has not run in 8 years in that time has had the carb off. Im wondering what you guys feel is the best way to handle getting the old boy(name Dam) started. I know the engine has been rebuilt has less then 10,000 mile and the card was rebuilt but never put back on.
DustyG.
1952 Chevy 1.5 ton
1949 Gmc 2 ton flatbed Dump
DUSTYG. #564326 08/12/2009 12:31 PM
Marvel Mistery Oil in all the cyl. let it soak then I would try and turn the engine over by hand if she turns drain the oil and change the filter , refill with some 30 wt. and a little marvel get clean gas to the carb ,I use a gas can with a pc. of hose to the pump . just a little gas down the carb and give her a try . check the plugs and the points first as Your soaking the cly's .fill the rad. with water so if there are any leaks it will not matter .
Good luck, Have fun , Pete
