| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2009 Posts: 21 | Going from what I believe was a fleetside and putting a stepside on it (it is a longbed frame) Are the mounting points different?
Yes this is my truck, No I wont help you move
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | will be evident with cross sill placement [I believe they're the same], but it doesn't matter, the mount holes in the frame can be matched up or new ones drilled - I found a minor difference in frame hole placement between years, may well be some variation between assembly plants as well
Bill | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Once you have them coated and ready to install glue the pad to the bottom with a little painters caulk it makes them much easier to thread bolts through. | | |
