5 members (WICruiser, 55shaker, Oswald, Bill Hanlon, 1955 1 Series), 178 guests, and 1 robot.
Topics128,263
Posts1,058,348
Members48,485
#560102 07/29/2009 5:40 PM
Going from what I believe was a fleetside and putting a stepside on it (it is a longbed frame) Are the mounting points different?
Yes this is my truck, No I wont help you move
will be evident with cross sill placement [I believe they're the same], but it doesn't matter, the mount holes in the frame can be matched up or new ones drilled - I found a minor difference in frame hole placement between years, may well be some variation between assembly plants as well
Once you have them coated and ready to install glue the pad to the bottom with a little painters caulk it makes them much easier to thread bolts through.
