| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 16 New Guy | | New Guy Joined: Jul 2009 Posts: 16 | I just took the bed off of the frame and removed the old rusted strips. But the angle strips on the each side of the bed panel seemed to be welded on. Is that how they are supposed to be? Should I just knock them off or is there a step I am missing  Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | they're originally welded - if the area is rotten, there are good repros available, if they're good, leave'em be
Bill | | | | | Joined: Mar 2000 Posts: 1,177 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,177 | They were tack welded on. If you need to remove them, the usual way to do it is to use a small drill bit to drill out the welds. If you try to pry them off, you could rip the metal of the bed side and end up with a lot more work to do. | | |
