3 members (Bill Hanlon, baldeagle, Ponchogl), 54 guests, and 8 robots.
Topics128,020
Posts1,055,345
Members48,420
#563968 08/11/2009 4:31 AM
I
I Offline
I just took the bed off of the frame and removed the old rusted strips. But the angle strips on the each side of the bed panel seemed to be welded on. Is that how they are supposed to be? Should I just knock them off or is there a step I am missing headscratch Thanks
1953 GMC 3/4-Ton
In Photobucket
In the wind, til the end
iceman1985 #563970 08/11/2009 4:36 AM
they're originally welded - if the area is rotten, there are good repros available, if they're good, leave'em be
Flxible #563971 08/11/2009 4:38 AM
Red dot, center of chest ...
They were tack welded on. If you need to remove them, the usual way to do it is to use a small drill bit to drill out the welds. If you try to pry them off, you could rip the metal of the bed side and end up with a lot more work to do.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
