| | | Forums66 Topics128,183 Posts1,057,262 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 4 New Guy | | New Guy Joined: Jun 2009 Posts: 4 | I have been trying to ID a GM 10 bolt rear end I have. The numbers stamped in the axle tube are: 7FHO 236 The casting number on the center housing are b555771. I would like to use this axle in my 52 if it's a 8.5" 10 bolt but I don't think it is. Any help identifying this rear axle it greatly appreciated. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 52 Rat, a picture would be great, how many axle studs does it have, how many bolts hold the cover on, and what shape is it? | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | What did it come out of??? I can't find any reference to either of those numbers in my parts or interchange books...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Feb 2000 Posts: 5,241 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,241 | Pull the cover and look for the GM numbers on the outer part of the ring gear. There will be the part number, gear ratio, and date code.
Joe | | |
