7 members (fonz8261, Rexville48, 1955 1 Series, Peggy M, mk72, Shardean, 55shaker),
60
Mod | | | Forums66 Topics128,022 Posts1,055,387 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 4 New Guy | | New Guy Joined: Oct 2008 Posts: 4 | what modifications do I need to do to get my 216 gas pedal rod to work on the 235 in my 1946 1/2ton? It appears long but I just located this original equipment one today and would like some guidence before modifing? | | | | | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | I was able to buy hookup components such as threaded rods and threaded swivels at NAPA. These components were apparently devoloped for "hot rodders" for use in custom installations You will need to envision what you need. meansam | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If your 235 is a 1959 or earlier you won't need to modify anything, it will bolt right on. If it is a 1960-62 there are a few options.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2008 Posts: 4 New Guy | | New Guy Joined: Oct 2008 Posts: 4 | 1956 engine and it does go right on, but will not connect to the pedal bracket.Could the pivoting arm on the block be backwards? As the engine is in the rig,NAPA is looking better all the time. Thanks for the help. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are two spots on a 56 235 for the throttle pivot. The front spot is in the same spot as the 216.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | Here'a a pic showing the stock linkage on a 55.1 -- the bellcrank pivot is in the forward hole, so the bellcrank is partially hidden by the exhaust outlet. Note that the rod from thew accelerator pedal pushes from the top, rotating the bellcrank ccw. Here's a better view of the 55.1 linkage from the assembly manual. Here's a pic showing a 62 235 with the bellcrank pivot in the aft hole. Note that it pushes from the bottom. I have no idea if this is stock for the late 235. regards, Leon | | |
