1 members (Tronman), 60 guests, and 2 robots.
Topics128,079
Posts1,056,310
Members48,442
#56311 02/10/2006 9:33 PM
Has anyone sucessfully 'unfrozen' a rusty emergency brake cable by soaking it in diesel, keroscene, AT fluid, using electrolysis, or anything?
I will appreciate any comments whether this can be done or bite the bullet and buy a new one.
Thanks in advance,
52 Ted
illegitimi non carborundum
52 T,
I would bite the bullet and buy new ones. My 46 cables were in the same shape.
I figured that even if I got them moving again, they would not work right. From my bicycle days, good cables are the recipe for smooth working controls. On bikes, we always dumped old cables...
You can get the plastic coated ones for a reasonable price. If you are going to go resto-correct, the steel wrapped ones are going to cost you.
You can try E-bay..it is hit or miss on NOS stuff.
I have gotten some free with lots of penetrating oil. But they will rust back up and freeze again.
Fred
52 3600
69 C-10
Not a bad price the Filling station wants $69.50 + shipping for a repo.
"If it ain't Steel it ain't Real"
"Earth the insane aslyum for the rest of the Universe"
41 1/2-ton, a work in progress
68 Shortbed stepside 327/325hp/700R4
You can buy a cable lubricator at your local moto~cycle shop that allows you to ''inject'' (i use) white lithium grease INTO the inside of your large ebrake cable. after you get it unfrozen, Keep pressing the grease can button until you hear grease come out the other end. put a rag @ the far end first.
It works GREAT
about $12.00
Jim & Caroline
I guess there is no magic formula to 'un-sticking' them and keeping them reliable. Guess I'll bite the bullet and get a new pair.
Thanks everyone for their replies - the 'Bolt' comes through as usual.
52 Ted
Pat.
I had the same trouble with the parking brake cable on my 46 one ton. Cables were rusted solid at front attachment point. New cables were not available.
Here's my solution. Remove brake cable from housing.
On a bench grinder, carefully grind away 1-2" of the cable sheathing on the 'front end' of the cable. Work slowly and carefully, rotating the cable to remove the metal housing evenly. When all sheathing is removed, soak cable in penetrating oil overnight.
Next morning, lock brake end in vise and work cable loose with vise grips. When free, coat
in grease. Attach a length of 1/8" aircraft cable with crimp clamps. Use 2 clamps. Crimp in vise.
Reinstall, attaching aircraft cable to parking brake linkage. Use crimp clamp, or 'u-type'clamps to secure. Adjust linkage as necessary. Remember to re-grease the 'open end' of the cable when you grease the truck.
My fix has lasted for two years and counting.
Good luck.
A Word of Warning....
i had a cable rusted up on the '51 for a spell... kept fighting at it, finally got it to working. Yeah! me thinks, until one week later when i go to put it on and BAM! Broke it good! The rust had weakend it enough to where it finally broke. Good thing i was still holding onto the back up emergency brake (aka block 'o wood).
Brakes are important. Important enough for new parts.
seems that i am still learning that lesson.
Build 'em to Drive 'em
