6 members (Oswald, 3B, 68ironhead, Gdads51, Gray_Ghost, 1 invisible), 138 guests, and 4 robots.
Topics128,151
Posts1,057,009
Members48,460
#562362 08/05/2009 8:32 PM
Can a 2 ton cab and front fenders and hood be used for a 1/2 ton truck or are the fenders and hood bigger? I am new to these trucks and I am wanting to build one on an s 10 chassis but only finding 2 ton trucks. thanks
The fenders, grille, bumper, and hood are bigger above 1 ton, but the cab is identical.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Use a full size truck frame then, since the fenders are longer & wider it'll fit better. As Dave said 1/2-3/4 & 1ton stuff is all the same...Joe
24601
24601
Be sure to check our FAQs and Tech Tips, too wink
And welcome to Stovebolt.com!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Or it gives you room for really wide wheels and tires when on an s-10 frame.
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
That's more like really really, really, really wide wheels and tires when on an s-10 frame. I say this because you have to run at least a 8" rim and maybe even with a one inch spacer behind the rim. Even w/just the 8" rims there is something like 3-4 inches between the tire & fender.
A tall spindle swap using full size GM spindles could be done but then a new upper control arm has to me bought or find someone to modify the stock one. With the swap you get 11 or 12 inch rotors & the tire/wheel is pushed out from 1" to 1.5".Joe
the hoods will interchange on most of the the early 60's trucks between c10's and c60's.
1 Offline
don't waste your time with s10 chassis use a fullsize.
