2 members (delky, dt235sd),
43
Mod | | | Forums66 Topics128,179 Posts1,057,157 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 6 New Guy | | New Guy Joined: Aug 2009 Posts: 6 | Can a 2 ton cab and front fenders and hood be used for a 1/2 ton truck or are the fenders and hood bigger? I am new to these trucks and I am wanting to build one on an s 10 chassis but only finding 2 ton trucks. thanks | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | The fenders, grille, bumper, and hood are bigger above 1 ton, but the cab is identical. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Can a 2 ton cab and front fenders and hood be used for a 1/2 ton truck or are the fenders and hood bigger? I am new to these trucks and I am wanting to build one on an s 10 chassis but only finding 2 ton trucks. thanks Use a full size truck frame then, since the fenders are longer & wider it'll fit better. As Dave said 1/2-3/4 & 1ton stuff is all the same...Joe | | | | | Joined: Nov 1995 Posts: 5,744 24601 | | 24601 Joined: Nov 1995 Posts: 5,744 | Be sure to check our FAQs and Tech Tips, too  And welcome to Stovebolt.com! John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Can a 2 ton cab and front fenders and hood be used for a 1/2 ton truck or are the fenders and hood bigger? I am new to these trucks and I am wanting to build one on an s 10 chassis but only finding 2 ton trucks. thanks Use a full size truck frame then, since the fenders are longer & wider it'll fit better. As Dave said 1/2-3/4 & 1ton stuff is all the same...Joe Or it gives you room for really wide wheels and tires when on an s-10 frame.
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Can a 2 ton cab and front fenders and hood be used for a 1/2 ton truck or are the fenders and hood bigger? I am new to these trucks and I am wanting to build one on an s 10 chassis but only finding 2 ton trucks. thanks Use a full size truck frame then, since the fenders are longer & wider it'll fit better. As Dave said 1/2-3/4 & 1ton stuff is all the same...Joe Or it gives you room for really wide wheels and tires when on an s-10 frame. That's more like really really, really, really wide wheels and tires when on an s-10 frame. I say this because you have to run at least a 8" rim and maybe even with a one inch spacer behind the rim. Even w/just the 8" rims there is something like 3-4 inches between the tire & fender. A tall spindle swap using full size GM spindles could be done but then a new upper control arm has to me bought or find someone to modify the stock one. With the swap you get 11 or 12 inch rotors & the tire/wheel is pushed out from 1" to 1.5".Joe | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | the hoods will interchange on most of the the early 60's trucks between c10's and c60's. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | don't waste your time with s10 chassis use a fullsize. | | |
