2 members (dt235sd, Sjm),
99
Mod | | | Forums66 Topics128,283 Posts1,058,505 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | I can't seem to find front shocks for my 60' C-60. Does anyone possibly have a part source or a part number I could try at my local parts store? Thanks for any replies!
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Beewrangler, shocks Delco p/n D775K = GM p/n 5549915 = Napa p/n NS37187 $32.09. Those shocks have an extended length of 14.25", a compressed length of 9.375", a 3/8" N.F. top mount stem, and a 5/8" cantilever stud mount on the bottom, hardware is included, hope that helps. | | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | My length at rest is 15.5 and the mount is 3/4 eye at either end.
| | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Beewrangler, does your truck have the factory standard torsion bar suspension, or the leaf springs and straight axle? | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Beewrangler, if you could give me your shocks extended length, and collapsed length I may be able to find them by specification, at rest length is no use to me at all. And you are saying that they fit onto a 3/4" stud at each end? | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy Beewrangler, according to my Euclid catalogue it should be there p/n E83210 = GM p/n 5557565, the upper mount is offset with a 3/4" hole, the width of the mount is 3.125", the lower mount is centered with a 3/4" hole, and is 1.75" wide, niether number would cross into Napa numbers, hope that helps | | |
