Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
#562305 08/05/2009 3:35 PM
I can't seem to find front shocks for my 60' C-60. Does anyone possibly have a part source or a part number I could try at my local parts store? Thanks for any replies!
240,000 worker bees!
1960 Two ton Chevy
3B Offline
Hy Beewrangler, shocks Delco p/n D775K = GM p/n 5549915 = Napa p/n NS37187 $32.09. Those shocks have an extended length of 14.25", a compressed length of 9.375", a 3/8" N.F. top mount stem, and a 5/8" cantilever stud mount on the bottom, hardware is included, hope that helps.
3B #562390 08/05/2009 10:02 PM
My length at rest is 15.5 and the mount is 3/4 eye at either end.
1960 Two ton Chevy
3B Offline
Hy Beewrangler, does your truck have the factory standard torsion bar suspension, or the leaf springs and straight axle?
3B #562437 08/06/2009 12:56 AM
3B Offline
Hy Beewrangler, if you could give me your shocks extended length, and collapsed length I may be able to find them by specification, at rest length is no use to me at all. And you are saying that they fit onto a 3/4" stud at each end?
3B #562532 08/06/2009 6:12 AM
3B Offline
Hy Beewrangler, according to my Euclid catalogue it should be there p/n E83210 = GM p/n 5557565, the upper mount is offset with a 3/4" hole, the width of the mount is 3.125", the lower mount is centered with a 3/4" hole, and is 1.75" wide, niether number would cross into Napa numbers, hope that helps
