| | | Forums66 Topics128,179 Posts1,057,138 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | Found a deal on 6 tires for my truck, but they're off a trailer. Is there a difference between truck tires and trailer tires? They are the same size, 8.25 x 20, on the same Dayton rims. Brand is Kumho. They would be for the rear, not the front. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy ScottGMC40001964, I don't know for sure, but trailer tires may not be designed to transmit torque to the road, maybe someone who knows more about tires than I do will let us know. | | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | Shouldn't be a problem, trailer tires are generally straight ribbed but can be used on the trucks back axle. You just won't have the traction as lug tires. Don't pass on a good deal just because they are trailer tires.
James | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | I'm no tire expert but all the tires I have on my firetruck came from a cancelled navy contract to build portable electrical generator trailers. I'm talking about huge trailers if that helps. The tires are all 8.25x20R.
I've seen no problems in two years of use. | | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | Thanks for the replies. This is more a play truck than a working truck and would rarely be used to haul anything, and even then no more than a ton. I'll contact them tomorrow. Looks like shipping will be in the $300-400 range, so if the tires/wheels are cheap enough it could be a good deal. | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | Just because they came off a trailer doesn't mean they were designed as trailer tires. I 'm not sure if anyone makes a trailer tire in 20" any more. It is common practice to move tires from a tractor to a trailer. I would worry about age of the tires more than anything else. | | | | | Joined: Dec 2008 Posts: 401 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 401 | One thing you need to be careful of is if they are retreads, and trailer tires can be retreaded up to 5-6 times, they can not be used as steer tires on the front axle. They can only be used a drive tires on the rear axle. The scrubbing of the rubber on the ground can cause the caps to come off the casing. Not to mention that running caps on the steer axle is illegal. Just be safe. | | | | | Joined: May 2008 Posts: 114 Shop Shark | | Shop Shark Joined: May 2008 Posts: 114 | Crenwelge makes a good point about tire age. Old tires wear quickly and blow out at the worst of times. For an occasional use truck (light use) try to keep the rear tires at 10 years or less and the front steer at 5 years. Keep your tire pressures correct, also.
James | | |
