| | | Forums66 Topics128,269 Posts1,058,404 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I started to put my transmission to the enginge. Got the flywheel on and the clutch (11 inch) and presure plate went to put the bell housing on and found out it the wrong one it for a 10.5. I found another bell housing but don't know what it fits 10.5 or 11 here is the number 462606 so can anybody tell me what it fits. Every time I try a search all I get is a bunch of stuff I don't want to know
thanks
1938 Gmc 1/2 ton
| | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy TheShoer, could you give us an idea what year stuff you're playing with, and what engine??? | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Its going between a 250ci('70 nova I think) and a T5 and all that is going in a 37 GMC
1938 Gmc 1/2 ton
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | The 462606 bellhousing is for a late '70s - early '80s "A" body. It is for a 153t flywheel with a 10 1/2" clutch. It also has a weird release arm because of the size of the "A" body. I would look for ANY 1/2 through 1 ton truck bellhousing from 1963 through 1978 or so.
best wishes,
Les | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Thanks Roadmark would you be able to give me some numbers I could look for
1938 Gmc 1/2 ton
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | The 462606 bellhousing is for a late '70s - early '80s "A" body. It is for a 153t flywheel with a 10 1/2" clutch. It also has a weird release arm because of the size of the "A" body. I would look for ANY 1/2 through 1 ton truck bellhousing from 1963 through 1978 or so.
best wishes,
Les what year did they change the size of the frt bearing retainer hole? ron | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | To TheShoer, You want a 621 type bellhousing for a v8 which has the large starter bulge. See; http://www.stovebolt.com/techtips/engines/bellhousings.html, but there a bunch of aluminum bellhousings out there that will work as well or better since you have to fab up everything anyway. I don't have a number list for the aluminum ones, but it should be on line. To padresag (Ron), I can't answer that, but I believe it is more based on application and engine than year. Most '60s 'Vettes used a "small hole" bellhousing with a 153t flywheel for a 10 1/2" clutch until about 1967, except the 427. The 6 cyl trucks from the same period with Muncie transmissions had the big hole to fit the trans and 160t 11" clutches. Go figure. best wishes, Les | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Thanks Roadmarks I read that link before and it did not quite answer my questions I have found a couple of numbers that will accept an 11 clutch. All I can say is I just don't remember going through all this stuff 35 years ago when I was in high school working on cars and trucks.
1938 Gmc 1/2 ton
