7 members (Ponchogl, Otto Skorzeny, moparguy, KEVINSKI, Brian Moore, 55shaker, ShopRag),
71
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 86 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 86 | The Reese trailer harness in my Jeep failed after less than 3 hours use. The turn signals and brake lights work, but the running lights don't. I traced it to the brown wire coming out of the Reese box (1 1/2 inches x 3 inches x 1/2 inch). The brown wire (running lights) going in is hot, the brown wire coming out is dead. My thoughts are to bypass the box with an inline fuse for the running lights. Any reason that wouldn't work?
Thanks, Scott | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I take it the "BOX" is a sealed unit ?...if it isnt take it apart and find out WHY it is dead an fix there if it a sealed unit I would do as you suggested and just jump around it, I dont see any reason it would hurt anything. Ya just gottta love trailor wiring!...seems no matter what I do every spring is a chore in gettin them all workin again between the PA winter salt and weather ...its either the tow vehicle or the trailor that needs TLC. Tim | | |
