2 members (JW51, WICruiser),
300
7
Mod | | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | I have a 59 with the motor (235) and trans (3 spd) out of a 62 just realized the 62 has a hydrulic clutch , can the 59 pedal be adapted to work the 62 hydraulic clutch? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. You'll need to use the bellhousing from a '55-'59, or from a '63-'72.
Bill Burmeister | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy phnman23, I think LONGBOX55 must have been thinking of a V8 when he told you to get a bellhousing for a 63-72. For the 235 you'll need a bellhousing for a 54-59 235 or 261, hope that helps.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Whoops! Ya got me! Had a bit of brain fade there, I was thinking about the clutch setup rather than what engine. Bad thing is that I did see that it was a 235 we're dealing with
Bill Burmeister | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | the 54-59 bellhousing will have the fork on the drivers side and eliminate the hydraulic? I was kind of hoping to use it somehow | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy phnman23, Yes the 54-59 bellhousing will allow you to use the stock clutch linkage, in my mind it's not worth the hassle of installing a clutch master cylinder to use the hydraulic clutch. | | |
