5 members (Oswald, DadsFirstPickup, Hotrod Lincoln, J Lucas, 1955 1 Series), 66 guests, and 1 robot.
Topics128,047
Posts1,055,622
Hi Guys --
I have not installed a crank in a long time. When the crank is in the block with everything clean et, new bearings, cap bolts just finger tight, shouldn't it spin freely? It doesn't want to turn. Wrong bearings?
Boo grin
We don't need no stinking V-8s!!
yup something is wrong. try it with one cap at a time... or try it with no caps? Its almost mandatory that you plastiguauge any new bearings anyway....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
Junior Member
Junior Member
make shure the locks in the bearings are facing oneanother
Get to work,millions on welfare are depending on you.
Have you had the crank machined or are you just installing new bearings? If you have a crank reground to say 0.020" under sized, you then need to buy 0.020" over sized bearings. You always want to plastigauge the clearances after you have the crank done to make sure the machinist did the job correctly and verify he gave you the correct bearings. Also make sure the lock tang on the back side of the bearing matches up with the notch on the top edge of the bearing journal. Crank should turn easily by hand even with all the caps torqued. The initial fitting should be done before the main rear seal is installed.
Good luck.
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
They were the wrong bearings!!! They almost fit, but with the clearance problems I took them bank to the parts store and, sure enough, we checked the numbers -- wrong bearings!
Boo
