1 members (1 invisible),
78
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56054 02/04/2006 9:52 PM | Joined: Oct 2004 Posts: 175 Member | | Member Joined: Oct 2004 Posts: 175 | Hi Guys -- I have not installed a crank in a long time. When the crank is in the block with everything clean et, new bearings, cap bolts just finger tight, shouldn't it spin freely? It doesn't want to turn. Wrong bearings? Boo
We don't need no stinking V-8s!!
#56055 02/04/2006 10:19 PM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | yup something is wrong. try it with one cap at a time... or try it with no caps? Its almost mandatory that you plastiguauge any new bearings anyway....
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#56056 02/04/2006 10:40 PM | Joined: Jan 2006 Posts: 8 Junior Member | | Junior Member Joined: Jan 2006 Posts: 8 | make shure the locks in the bearings are facing oneanother
Get to work,millions on welfare are depending on you.
#56057 02/05/2006 4:20 AM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Have you had the crank machined or are you just installing new bearings? If you have a crank reground to say 0.020" under sized, you then need to buy 0.020" over sized bearings. You always want to plastigauge the clearances after you have the crank done to make sure the machinist did the job correctly and verify he gave you the correct bearings. Also make sure the lock tang on the back side of the bearing matches up with the notch on the top edge of the bearing journal. Crank should turn easily by hand even with all the caps torqued. The initial fitting should be done before the main rear seal is installed.
Good luck.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#56058 02/06/2006 12:53 AM | Joined: Oct 2004 Posts: 175 Member | | Member Joined: Oct 2004 Posts: 175 | They were the wrong bearings!!! They almost fit, but with the clearance problems I took them bank to the parts store and, sure enough, we checked the numbers -- wrong bearings!
Boo
