| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 11 New Guy | | New Guy Joined: Nov 2007 Posts: 11 | I own a '71 C20, 350 eng, TH350, long bed, coil rear springs, 4:10 posi rear. I would like to install a 454 BB, and I'm concerned with clearance for headers. This engine is currently installed in my '86 K1500. *Also, I know I've got size issues with an aftermarket "Be Cool" aluminum radiator. Do you'all know of anyone installing a 454 in a stock C20? I believe it should bolt right up to the TH350. Thanks in-advance for your comments & info. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 454 will bolt right in, just need the correct motor mounts. The 396/402 was a factory option on thes trucks, so it won't be an issue. I would suggest going to a TH400 behind that big block, though. That's what the original BB trucks ran.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Or go with a 4L80E and trans controller to get overdrive.
| | | | | Joined: Nov 2007 Posts: 11 New Guy | | New Guy Joined: Nov 2007 Posts: 11 | I have a 700R4, but it's for a 4WD truck. Thanks for the replies. I'm mostly worried about clearance for the headers, and that $600.00 aluminum radiator. I was going to put this '71 cab & front clip on a built '86 GMC 4x4 frame. I've decided to keep the '71 stock except the engine. I love my 454, and I know it will breath new life in my C20. | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | The 454 will bolt in on 350 mounts, they are in the same location. A decent set of headers should clear all your accessories. If your current radiator is keeping the 350 cool, it should do OK in all but extreme conditions with a 454. Same with your TH350.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I agree the 454 will bolt in, but my experience with big blocks is they make lots of heat. I'd look for a bigger radiator like they used in big block trucks.
And if you stay the the TH 350 either drive real nice or carry a spare.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2007 Posts: 11 New Guy | | New Guy Joined: Nov 2007 Posts: 11 | I'll take it easy on the TH350, but I've been told that tranny can be beefed-up to handle 500 HP. Don't know if that's true. My 454 only puts out 365-375 HP, I think I'll be okay. My aluminum "Be Cool" radiator is currently installed in my '86 GMC, I'll have to fabricate brackets to implement its installation in the '71's radiator core support bracket. Inner fender wells might be a problem touching my headers. So, I might just use stock exhaust manifolds, if I can locate some. Otherwise, I'll trim/beat a little metal out of the way. Thanks again for the responses.  | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Jeff, Jegs have a alum. radiator that you can pick the size. I bought a double core for less than 250 and it is great. | | | | | Joined: Nov 2007 Posts: 11 New Guy | | New Guy Joined: Nov 2007 Posts: 11 | Thanks for the Jegs info. I have 2 electric fans located on the back side of the radiator, and a third one in front, for pushing air (for emergencies only). I think it would save a lot of money if I could retro-fit/shoe-horn this radiator onto the '71's core support bracket. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I still say, go with a 4L80e and controller. The 4L80E is the transmission that GM put behind the 454's and 496's. Its an electronic overdrive version of the old TH400 http://www.tciauto.com/Products/Electronics/default.asp
