5 members (Phak1, BC59, MickeyP, Oldcaliforniakid, Gdads51), 85 guests, and 2 robots.
Topics128,049
Posts1,055,667
#560074 07/29/2009 3:34 PM
After my 228 GMC stalls and wont restart after running for awhile, no spark. Given adequit rest time it starts fine. System is origional 6volt. Coil gets pretty hot. Is this due to a lack of a ballast resister, bad coil etc.? Any ideas?
Shouldn't need a ballast resistor. When this happens check the circuit with a trouble light until you loose power also check all the wiring and connections.
Shop manual should tell you how to check the coil or local auto parts may be able to check it also.
1946 1/2-Ton Chevy
Classic symptoms of a backward wired coil. Since GMC's are POS ground, the "hot" wire from the ignition switch goes to the NEG side of the coil.
jdl Offline
Also could be that it IS a bad coil. One would think that if something is wired backward nothing would work, right? If I went outside and rewired my coil I'm pretty sure it wouldn't work, but I may be wrong. From what I've heard it sounds like the coil is bad but it could be something else.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Coils will work with the polarity reversed. However, as coils warm up, the windings expand. If the insulation is bad, the coil will stop functioning. If this is the case, replacing the coil is the only option. 6 Volt coils do not need resistors when used in a 6 volt system. Try a different coil and make sure the polarity is right.
Checked wiring on Coil. + terminal is connected to ignition swith, - terminal to distributor. I guess next step is replacing the coil. Any more advice?
I agree with the bad coil theory. It will work whether or not the polarity is correct.
1951 1 Ton Completed
