Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#559870 07/29/2009 12:37 AM
Just got my 52" 235 running,but now it looks like the fuel pump is going out.Will gravity fill the pump after sitting awhile?
Doing this with the bulb full of gas prime it to getting to work again?
joes1952 #560033 07/29/2009 2:20 PM
Ex Hall Monitor
Ex Hall Monitor
All of the bad fuel pumps I've dealt with failed because the diaphragm cracked. If that is the case with yours you'll need to rebuild or replace it.
Tiny #560043 07/29/2009 2:35 PM
When you take the fuel line off the pump that comes from the gas tank you should have fuel coming out. If you don't have fuel coming through the supply line you may have a plugs fuel line? Is you gas cap a vented cap?
Couple Ideas - Good Luck
Don
don stocker #560148 07/29/2009 7:58 PM
jdl Offline
In addition to and restating some of the above: It could be that your gas tank has crud in the bottom and is clogging the pickup tube in the tank when the fuel pump sucks the gas to the engine. You could have the same situation just before the fuel pump, or up by the carb. It could be that your fuel pump is indeed going bad. If you have a fuel filter anywhere in the system it could be plugged up. Stuff could be inside of the carburetor. About the only way to diagnose what is wrong is picking points in the fuel system and inspecting them. I'd start at the carburetor or fuel filter(fuel filter first if you have one, not all did) and then work on back to the fuel pump and lines to the tank. Good luck, and someone with more experience may come along and tell you more specifically what could be wrong but I'm not sure exactly what's wrong so...smile Good luck and I hope you find what's wrong with it.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
