1 members (baldeagle),
38
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | Just got my 52" 235 running,but now it looks like the fuel pump is going out.Will gravity fill the pump after sitting awhile? Doing this with the bulb full of gas prime it to getting to work again? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | All of the bad fuel pumps I've dealt with failed because the diaphragm cracked. If that is the case with yours you'll need to rebuild or replace it.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | When you take the fuel line off the pump that comes from the gas tank you should have fuel coming out. If you don't have fuel coming through the supply line you may have a plugs fuel line? Is you gas cap a vented cap? Couple Ideas - Good Luck Don | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | In addition to and restating some of the above: It could be that your gas tank has crud in the bottom and is clogging the pickup tube in the tank when the fuel pump sucks the gas to the engine. You could have the same situation just before the fuel pump, or up by the carb. It could be that your fuel pump is indeed going bad. If you have a fuel filter anywhere in the system it could be plugged up. Stuff could be inside of the carburetor. About the only way to diagnose what is wrong is picking points in the fuel system and inspecting them. I'd start at the carburetor or fuel filter(fuel filter first if you have one, not all did) and then work on back to the fuel pump and lines to the tank. Good luck, and someone with more experience may come along and tell you more specifically what could be wrong but I'm not sure exactly what's wrong so...  Good luck and I hope you find what's wrong with it. | | |
