| | | Forums66 Topics128,264 Posts1,058,352 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | have a 57" 235 6 volt with very weak spark,coil and wiring good what else could it be? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | that little condenser in the distributer. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Also could be point gap, distributor cap, wrong wires (I would use stranded copper plug wires for this set-up), worn out distributor bearings. | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | I had the same problem in my 56 235... Condensation had left a "glaze" (corrosion)on the points almost impossable to see, with my eyes anyway, a trip to toe wire wheel regap at .016 and she ran. Also are you SURE it is a 6 volt? Should be a 12volt in 57. Brad | | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | the trucks a 52" the motor is a 57" yep its a 6 volt. | | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | thanks for all the feedback now all I have to do is work on it. | | | | | Joined: Sep 2007 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 154 | Double check the coil. You should have a nice blue spark at the end of the plug wire and it should jump at least an "1/8. A poor coil will/could give you a spark but it will show up with a yellow tint to it and it will not jump quite as far. Also a good strong battery is important. | | | | | Joined: Apr 2009 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 54 | well finally got around to changing the plugs to non-resistor and to copper wires and it fired right up,after ajusting the idle it ran good.but now I think I have a fuel pump problem. | | |
