4 members (1955 1 Series, Barney1951, Millenimech, 1 invisible), 79 guests, and 2 robots.
Topics128,032
Posts1,055,438
Members48,422
#559297 07/27/2009 12:35 PM
A friend of mine has been having some problems with his trucks carb getting too warm and boiling the gas and causing it to vapor lock after about 3 miles. It's got a 6 cylinder and the original one barrel carb. I'm thinking it needs a spacer plate and some insulation on the fuel lines, or is it something bigger like the fuel pump? Thanks for the help.
Tramp
dj durant
More pix on Flickr
Tramp #559305 07/27/2009 1:33 PM
Ex Hall Monitor
Ex Hall Monitor
If the heat riser is stuck in the heat on position it can get the carb too hot but that normally will cause hard start when hot issues more than vapor lock. My experience has been that vapor lock is a symptom of a weak fuel pump. There are anecdotal stories about having success in "curing" vapor lock using old clothes pins stuck to the fuel line but that's never worked for me.
Tiny #559708 07/28/2009 5:21 PM
I agree with Tiny, that a strong fuel pump is the first step in eliminating vapor lock. However, I think the Evil Vaporlock has become something of a scapegoat for all manner of other problems.
I'd follow your hunch and install a spacer under the carb, check the fuel line routing and maybe insulate the line where practical. But, I'd also consider checking/rebuilding/replacing the fuel pump, checking/rebuilding the carb, and then thinking about whether the engine is cooling itself properly, ie: the heat riser, proper coolant/water ratio, good flow through the radiator, etc.
Heck, while you're at it, just rebuild the whole engine!!! smile
I've been told by Carb King that the Gold Standard for addressing the crappy gas we get nowadays, is to intall a three-line fuel filter prior to the carb. One line in from the pump, one line out to the carb, and one smaller line returning to the gas tank. This allows excess gas (and vapor?) to return to the tank. With a good fuel pump, you always have good fuel pressure, and circulating, COOL fuel in the lines. A side benefit is that you gain a small percentage of horse power from the cooler fuel input. Or so I'm told.
Kinda a pain in the A$$ to plumb a line back into the tank, though . . .
Anyway, those are the thoughts of THIS shade-tree mechanic . . .
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Mikestem #560415 07/30/2009 7:19 AM
Depending on the year it should have a phenolic spacer under the carb to prevent the gas boil out.
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
