3 members (Hotrod Lincoln, baldeagle, 1 invisible), 77 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,420
#55933 02/02/2006 12:12 AM
Hi all,
I finished my '51 3800 and have been driving it around for a year or so with a '48 235 splash oiler. It didn't take me long to decide I'd rather have a later model 235. I now have a 235 out of a '59 pickup all cleaned up and ready to go in the truck.
I was planning to remomve the radiator and front grill before the swap but thought I'd ask before I do the deed. Do I really need to take the grill off or will pulling the radiator be enough? Any other tips from those of you who of done this before?
#55934 02/02/2006 12:20 AM
Riding in the Passing Lane
No you do not need to pull the grill. You will probably leave the trans in though. You will need to modify the water pump on the engine going in. It is too long to clear the radiator. I understand there is an adapter available for this. There has been some recent posts & info in the tech. section.
1972 Chevy c10 Cheyenne Super
#55935 02/02/2006 12:50 AM
Thanks, that'll save some work.
I already have a short shaft water pump so am prepared for that. I've read the info in the tech section; I'll have a look through the posts.
#55936 02/02/2006 1:06 AM
I wish someone would show me a pix of a short shaft water pump............Fred
Redryder pix
My Hotrod
#55937 02/02/2006 1:24 AM
Hey Joker,Look on page 70 of your Chevy Duty catalog or go to www.chevyduty.com for a picture.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#55938 02/02/2006 2:23 AM
thanks,,,,,,,,,,,,,,,Fred
Redryder pix
My Hotrod
#55939 02/02/2006 2:35 AM
Fred, come on over and look at the one on my yarddog. Wear your work clothes. wink
#55940 02/02/2006 2:39 AM
thanks, just curious about the one on my 52, looks like the long one but the truck has a 58 or so 235 in it, and the radiator looks like it is in the normal positon,,, I will pass on your offer and let you check mine out at the meet on the 24th grin Fred
Redryder pix
My Hotrod
#55941 02/17/2006 9:39 PM
What parts do I need to get, if I want to put a powerglide (1956) trans into my 1960 Chevy with a 235 engine. It has a standard trans now.
#55942 02/18/2006 3:34 AM
PaFarmer
The adapter works great and lets you put the old style pump back to the right place. The short shaft pump leaves the fan to low and can lead to over heating in slow speed conditions. It's easy to install and lets you use a over the counter pump.
