8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall), 122 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#55929 02/02/2006 12:06 AM
My 228 GMC has an oil line running from the front of the head to a brass block on the lower front left end of the engine block. I understand this is a pressure line for the head but the brass block has another threaded hole. Should there be another line running to a different part of the engine?
G.Lee
#55930 02/02/2006 2:30 AM
My Master Parts Book shows another line running from the bottom of the brass junction block along the left side of the engine but doesn't show what it goes to.
#55931 02/02/2006 1:21 PM
Thanks Cletis. That gives me something to work with. Unfortuanatly the engine was so badly caked in crud when I took pictures I cant see what lines there were.
G. Lee
#55932 02/03/2006 7:51 AM
http://www.oldgmctrucks.com/page0289.html
Go here , this will show where your lines are routed. Cecil..........
