0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
#55922 02/01/2006 9:36 PM
Junior Member
Junior Member
Hi everyone. I am new here so bear with me. I have a 1955 2nd series chevy truck that I have put power steering in. It uses a gm saginaw box. The box is leaking and I want to rebuild it. Does anyone have any info on doing this. Any help would be appreated......now where is the spell check....
James
Working on my 55 2nd series to make it a daily driver.
http://www.hotrodders.com/forum/journal.php?journalid=26732&action=view
#55923 02/01/2006 10:59 PM
James M,
Unfortunately, I am no help in the rebuilding department. But I have a 55 2nd series and want to add a power steering box too. Would you be willing to shoot me an email and tell me how you did it? Pictures would be great too! [email protected]
#55924 02/01/2006 11:04 PM
Riding in the Passing Lane
A complete rebuild is pretty tough job but it,s easy to put seals in. Get the steering on center & remove the 4 bolts on top. Pull the cover & sector shaft out. The pitman arm must be off. Then you can put in the lower seals. Remove the lock ring on top & unscrew the adjuster plug holding the shaft down so it wont come up. Then replace the seals in the adjuter plug. When installing the adjuster plug teighten it down all the way & back it up just a little.Their should be no play in the shaft.
1972 Chevy c10 Cheyenne Super
James,If the box is leaking at the pitman arm seals you can change them without much trouble.(1)Remove the pitman arm with a puller.(2)remove the snap ring for the seals.(3)Reinstall the pitman arm and nut,without lock washer.(4)put a LARGE drain pan under gear box to keep mess to a minimum.(5)start truck and go full steering stop right or left.(6)hit the gas a few times and the seals will push out against pitman arm.When going back together make sure your shaft is clean,rust free and lube the seals with a vasoline type lube.NOT K-Y lol.Did this many times over my 20 years with a GM dealer.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Junior Member
Junior Member
Thanks guys...I have the steering box on the bench right now. I figured it would have to be off to fix it. Ans yes the seals are the main thing I need to repair. It leaks around the input shaft.
Thanks guys I might message you guys for more info as I get into it....thanks ahain
#55927 02/02/2006 10:17 PM
Apprentice
Apprentice
This might be helpful. http://jimshea.corvettefaq.com/?page_id=5
Jim posts on the www.camaros.net board that I frequesnt also.
I have his articles saved in .pdf format as well if you need them. grin
