| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55916 02/01/2006 9:12 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | I would like to keep the fine looking wheels on my 1939 3/4 ton. They are six lug. I could use some info to get better brakes, not necesary disks, but could use bendex style. thanks
"It ain't a truck if you can't hose out the cab."
#55917 02/01/2006 10:10 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Howdy Chester,
I take it you are worried about having to change wheels if you change brakes?
Somewhere close by is a post on a a type of brake shoe material that you can put on the Huck style brakes to improve stopping power. I will poke around and see if I can find it.
Are you running a 216 or something with more horsepower with the need for more brakes? Some may argue that Huck brakes are adequate for our trucks if we keep the stock engine etc.
I am running huck brakes on my 46 and did not mind them. Granted, I am not running in city traffic. | | |
#55918 02/01/2006 10:18 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | check out the dyno brakes post Check out this topic. there is a post about a type of brake pad that might help out. | | |
#55919 02/02/2006 3:31 PM | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | Don't have an answer for you but my thinking is the same as yours. I have a 39 3/4 (missing the cool artillery wheels) and i'm trying to figure out how to put early 50's bendix brakes on the front. I'm hoping there are some disk brake converters out there who will part with their old bendix units. There were some freebies advertised but I could never get with the fellow. If I locate a set, I can then start the process of seeing what matches up. I would probably start with the backing plates and work my way out. Might, however, need to change spindles. If you know something I don't know, keep in touch and share. Maybe we can work this out togeter. | | |
#55921 02/02/2006 9:34 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Thanks for the input, great stuff. I have been restoring the huck system. there is a post on Stovebolt Tech Tips under '55 Brakes & Rear for a '40. But '54 and '55 pickups are few to find around here, and i would like to be sure before i shop swap meets.
