| | | Forums66 Topics128,175 Posts1,057,115 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | I've got everything else for these spotlights except where exactly do the go. I need a template or measurements. The factory spot is below the windshield and above the door. Some one must have a truck with the spotlights on it! spotlight installation instructions
| | | | | Joined: Dec 2008 Posts: 337 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 337 | Have you checked out this link yet - http://picasaweb.google.com/normanmeloche/SpotlightTemplate#Click on the picture, then click on the magnifying glass in the upper right to bring it up full size. It can be downloaded so you can manipulate as needed. Hope this helps. Thanks to aerotruck63 for posting. | | | | | Joined: Jun 2009 Posts: 54 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 54 | That is my link, I'm trying everywhere to find someone with a template or a measurement. Unity bracket is different from the factory bracket cast by AUTOLITE. Any help would be appreciated.
