3 members (Shade Baby, 2 invisible), 134 guests, and 3 robots.
Topics128,260
Posts1,058,318
Members48,485
#558813 07/25/2009 6:22 PM
Hi guys,
does anyone know if it is possible to find a 6 lug drum (front) that fits an 8 lug truck? Meaning, can I pull off my 8 lug drum and replace it with a 6 lug without changing anything else in the front end?
I put a 6 lug rear end in my 3/4 ton, but now I have 6 lugs in the rear and 8 lugs in the front. I want to keep the truck drum brakes. So basically I am looking for front 3/4 drums that only have the 6 lug pattern. Does any company make this?
Thanks much
1966 Chevy C-20 Fleetside Longbed
Photobucket pictures
"Better get busy livin' or get busy dying" ~ ...Morgan Freeman
I
I Offline
Don't know what year you're workin on....but, 3/4's have larger spindles and bearings. Easiest way would probably be to change out entire front axle for a half ton (6-lug). Maybe find someone who changed over to IFS.Should be a bolt in.
The answer is probably no, but without knowing exactly what you have its hard to say.
I have a 3/4-ton with six-lug hubs, but its a '91 K2500. Some early 3/4-tons were six-lug. I don't know if the spindles are the same size as later eight-lug trucks or not.
What do you have?
You'll have to change the spindles, and possibly the control arms as well, if the 1/2 ton balljoints won't fit. Basically, a reverse version of what guys do to get front disks on the '63-'70 trucks. You might consider using the disk brake spidles, with the later balljoints for 1/2 ton, then use the 6 lug aftermarket rotors. That way, you get better braking and 6 lug.
Bill Burmeister
thanks guys,
sorry I forgot to mention what I have.
It is a 66 3/4 ton fleetside, with manual transmission.
thanks again, keep the tips coming!
I'd swap the whole front crossmember.
