3 members (JW51, 49choptop, Patina 54), 210 guests, and 6 robots.
Topics128,098
Posts1,056,167
Members48,436
#55871 02/01/2006 12:19 AM
Junior Member
Junior Member
1 Offline
Hello all! I am the proud new owner of a 58 Apache. We would like to find a reman carb but I cant seem to find one anywhere! We have a Rochester 2-Jet with an Automatic Choke. The choke is heat not linkage. The engine is a 283. The carb number is 7008597. Can anyone help us??
#55872 02/01/2006 2:26 AM
Z
Z Offline
did you try autozone?they had one for a 61 235.
#55873 02/01/2006 3:06 AM
Junior Member
Junior Member
1 Offline
Yeah, they couldnt even help. I have called every shop in town, Carburetor Exchange, American Classic Truck, Auto Parts Restoration and a few others. Would a 235 fit a 283?
#55874 02/01/2006 3:29 AM
3B Offline
Hy 1958Apache, could you not rebuild your carb if you got a kit? A carb for a 235 would be a single barrel, a 283 is a two barrel. I found an AUTOLINE PRODUCTS LTD. number in an old catalogue C912 AUTOLINE is from Winnipeg Manitoba
#55875 02/01/2006 4:17 AM
can't believe ya can't get a rochester 2 barrel, NAPA right above the border can have it next morning, if they don't have one on the shelf - maybe just because of the auto choke? how about one w/ a manual choke and switch the choke stuff over from yours?
#55876 02/01/2006 2:38 PM
Carquest is usually pretty well stocked for old GM parts also. Might want to check for swap meets coming to your area then theres always Ebay.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#55877 02/01/2006 3:02 PM
You might check with Langdon Stovebolt...they sell a really nice 2bbl Holley Weber w/ electric choke for that application.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#55878 02/01/2006 11:25 PM
Riding in the Passing Lane
These arn,t hard to o-haul if you have any mechanic skills. Or find an old timer that can do it. Half the reman carbs don,t work right & don,t match the engine. If you do get a reman Of all things don,t turn in the old carb. untill the the job is done & you are satisfied. Check with Carbking. He posts a lot on this websight & can rebuild it for you or give some ggod advice.
1972 Chevy c10 Cheyenne Super
#55879 02/05/2006 3:07 AM
If it was mine I'd go on ebay and get a 4 barrel manifold for any small block and an appropriate Rochester 4GC carb, and call it could. The right 4GC should improve both gas milage and performance. Ask Jon (carbking) for the right numbers to get the perfect carb.
Boo
We don't need no stinking V-8s!!
#55880 02/05/2006 5:19 AM
the biggest problem I've run into with "rebuilding" carbs is loose throttle shaft clearance. you can probably install a kit in your carb,but if the throttle shaft is worn,you get a variable,intermittent vacuum leak,which will make it impossible to tune properly.Even some professional carb rebuilders overlook this part,so it's worth doing some research first to be sure re-bushing the throttle shaft is part of every rebuild. If Carbking is being recommended on this site,you can be pretty sure you'll get a quality rebuild there. These guys don't settle for cutrate work.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#55881 02/06/2006 9:21 AM
Check with carbking who posts on here often.
