| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Does anybody have the relationships of the cab mounting points to the radiator support mounting point or can give me a clue where to find it. I though I was all set with my 53 frame on top of the 73 suburban frame, but I think I set my radiator support too high. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Ummm, you mounted your 53 frame on a 73 Burb frame?
I think you need to rephrase the question. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Yes I did. http://i621.photobucket.com/albums/tt292/53monster/starting%20block/j076.jpgIn this picture you can see the location of the front cuts on the 53 frame. http://i621.photobucket.com/albums/tt292/53monster/starting%20block/j074-1.jpg What I need is the relationship between the four cab mount holes to the two holes for the radiator support. I am good with the horizontal location, what I need is the vertical difference. If somebody has a frame sitting around, just lay a board on the cab perches and get me a vertical difference to the cross piece of the frame where the radiator sits. I hope I am getting my point across, if I'm not and somebody gets it help in explaining would be appreciated. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I've got a 54 1/2 ton frame and measured with straight edge on top of the rails out to the radiator support cross member. I come up with 4 5/8". | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Well I don't have a bare frame but I just checked from the ground up to where the rad mounts to the crossmember and got 14 3/4". Then I measured from the ground to the underside of the front cab mount and got 21.5". In my case the rad mounting point is 6 3/4" lower than the cab mount(on a 1952 1/2 ton). Hope that helps.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Thanks guys, my truck was a 3/4 ton but I don't think the answer would be different because of that. after all it is the dimension that sets the relationship of the front clip to the cab and the body parts are all the same. My best guess from taking measurements on my already cut frame was about 5" so we are narrowing it down. | | |
