1 members (Patina 54),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 6 New Guy | | New Guy Joined: Apr 2009 Posts: 6 | I'm just about to complete a front disc brake conversion on my 53 chev to go to a 5 on 4 3/4 bolt pattern. I would prefer to keep the stock hub caps. Does anyone know of a manufacturer, or another chevy car that I can get rims for the front from? Can the truck hubcaps cross over to 15" car rims from the 50's onwards? I'm running the stock 6 on 5 1/2 in the rear and could also use a new set of rims for that since my current rims are non-original and non-matching.
Cheers! Marcus | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | wheel vintigues and others like stockton wheel can fix you up with about any thing but there if you want to pay the price . | | | | | Joined: May 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 27 | I just got mine in today from http://www.rallyamerica.com/I provided the measurements and they fabricated what I needed- reasonable cost, too.
Bluesharp- If you don't blow you suck....
'50 Chevy 3600 "Ernest"
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I tried to use the 49-52 passenger car wheels on my 56 when I did the disc conversion. They have a similar center section with clips like the truck but would not work. I subsequently purchased some after market wheels from Wheelsmith in Santa Ana, CA. They are dual pattern (4 3/4 & 4 1/2)commonly refered to as smoothies. They have a center that is similar to a rally wheel. He also took my stock caps and cut off the part that presses into the wheel and replaced it with a smaller ring. They have been on the truck for about 8 years. Fred
| | | | | Joined: May 2008 Posts: 22 Apprentice | | Apprentice Joined: May 2008 Posts: 22 | chevy s10 older monte carlo 80 model regals and cutlas had the same bolt pattern even corvettes used it | | | | | Joined: Apr 2009 Posts: 6 New Guy | | New Guy Joined: Apr 2009 Posts: 6 | Thanks Guys. Another supplier I found is Early Wheel, www.earlywheel.com, based out of California. Cheers! Marcus | | | | | Joined: Mar 2009 Posts: 12 New Guy | | New Guy Joined: Mar 2009 Posts: 12 | When you did the disc brake swap did you go from a 6 lug to the 5 lug? I would like to do that but I thought you had to get different hubs and or whatever else...Can I just get a 5 lug kit and bolt it right up?
Thanks, Mike | | |
