5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
I would like to know if anyone out there has install a 77 to 87 pick-up front bolt in suspension into a 1954 chevy pick-up?Did you run into any problems?How did it drive and ride?Any info would be of great help.I am not installing a mustang 2 front end so i do not need to go there.All G.M. Thank you. Do i need to know of any problems before getting started.....
ubb
Newton54
One of my friends has A 54 with everything from a pickup that model under it,the K member with A frames and tie rods and suspension components looks like a good fit with a half inch steel plate for shims on the outside of each frame rail. The outside width is a little more than would be ideal,however it drives and rides good.
The steering box from the later pickup was also used and mounted in front, in same location as it was on the original truck frame I dont know how that location was determined ....good luck
Ronnie
I just posted links to two sites talking about this swap on the GMC forum. You can sign up there to find them, or just search Google.
1954 GMC De Luxe COE
Riding in the Passing Lane
I was looking at one a while back. It looked a little awkward with the wheels sticking out too far. I understand you can cut a section out of it & make it fit better. I like this swap better because you maintain the stock rideing heigth.
1972 Chevy c10 Cheyenne Super
