| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55790 01/31/2006 1:32 AM | Joined: Dec 2005 Posts: 11 New Guy | | New Guy Joined: Dec 2005 Posts: 11 | I would like to know if anyone out there has install a 77 to 87 pick-up front bolt in suspension into a 1954 chevy pick-up?Did you run into any problems?How did it drive and ride?Any info would be of great help.I am not installing a mustang 2 front end so i do not need to go there.All G.M. Thank you. Do i need to know of any problems before getting started.....
ubb
#55791 01/31/2006 1:59 PM | Joined: Feb 2005 Posts: 68 Member | | Member Joined: Feb 2005 Posts: 68 | Newton54 One of my friends has A 54 with everything from a pickup that model under it,the K member with A frames and tie rods and suspension components looks like a good fit with a half inch steel plate for shims on the outside of each frame rail. The outside width is a little more than would be ideal,however it drives and rides good. The steering box from the later pickup was also used and mounted in front, in same location as it was on the original truck frame I dont know how that location was determined ....good luck Ronnie | | |
#55792 01/31/2006 8:30 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I just posted links to two sites talking about this swap on the GMC forum. You can sign up there to find them, or just search Google. | | |
#55793 01/31/2006 10:50 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I was looking at one a while back. It looked a little awkward with the wheels sticking out too far. I understand you can cut a section out of it & make it fit better. I like this swap better because you maintain the stock rideing heigth. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
