1 members (MickeyP),
110
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | Can I safely put 650-16 tires on stock rims while maintaining 4600 gross weight capacity? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you find any brand of a 6 ply tire you should be ok. You can do a search and find many outlets for them.
Good Luck Don | | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Do you have a 16" 1941 rim? 4.0 rim section-width?
A 4.5 section width was usually used by GM for use with 6.50x16" bias ply tires.
Still, a professional and knowledgeable tire person would know what size-width bias ply tire will fit on wide rim width.
| | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | Do you have a 16" 1941 rim? 4.0 rim section-width? Yes, and I've seen a bunch of people using 650-16 tires on apparently stock rims and also Jim Carter sells them, but I was worried it would reduce load capacity if I put oversized tires on 4.0 rims. | | |
