4 members (2-Ton, Robert Crandall, JoergK., Phak1), 71 guests, and 5 robots.
Topics128,188
Posts1,057,216
Members48,465
#557762 07/22/2009 5:19 PM
Can I safely put 650-16 tires on stock rims while maintaining 4600 gross weight capacity?
Are you talking bias ply or radial?
Bias Ply: Load Capacity: 1580 @ 32 psi, 1580 x 4 = 6320 lbs
http://store.coker.com/650-16-coker-classic-blackwall.html
Radial: No Rating
http://store.coker.com/650r16-coker-classic-blackwall-tire.html
If you find any brand of a 6 ply tire you should be ok. You can do a search and find many outlets for them.
Good Luck
Don
But will they fit??
Do you have a 16" 1941 rim? 4.0 rim section-width?
A 4.5 section width was usually used by GM for use with 6.50x16" bias ply tires.
Still, a professional and knowledgeable tire person would know what size-width bias ply tire will fit on wide rim width.
Yes, and I've seen a bunch of people using 650-16 tires on apparently stock rims and also Jim Carter sells them, but I was worried it would reduce load capacity if I put oversized tires on 4.0 rims.
