1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | I have removed the axels themselves. Now I need to remove the lock nut to get to the bearings. It is round with places for 6 fingers to fit in. The shop manual calls it "Special Tool J-2222". NAPA informed me they couldn't help me but suggested using a punch. I don't want to do it this way as to not destroy the threads. Any vendors carry this or do I use a punch?? | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | A good auto parts store will have an axle nut socket for you, but you could as easily use a punch. Napa sucks, at least around here. Theres probably a lock washer between two nuts with fingers that are bent over the notches, these should be pried up with a screwdriver. Then you can remove the axle lock nut.
Hope that helps.
Jeff | | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Answered my own question.
It's a 6-slot 4WD Wheel Bearing Locknut Tool. Designed for 1978-Current F-Series 3/4 & 1 Ton Trucks and 1973-1981 GM 3/4 & 1 Ton Trucks.
15 Bucks at Advanced Auto Parts!!! | | |
