6 members (Oswald, farmallb, Stovebolt48, GrandpasJimmy, 2 invisible), 132 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#557271 07/20/2009 10:14 PM
I have removed the axels themselves. Now I need to remove the lock nut to get to the bearings. It is round with places for 6 fingers to fit in. The shop manual calls it "Special Tool J-2222". NAPA informed me they couldn't help me but suggested using a punch. I don't want to do it this way as to not destroy the threads. Any vendors carry this or do I use a punch??
A good auto parts store will have an axle nut socket for you, but you could as easily use a punch. Napa sucks, at least around here. Theres probably a lock washer between two nuts with fingers that are bent over the notches, these should be pried up with a screwdriver. Then you can remove the axle lock nut.
Hope that helps.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Answered my own question.
It's a 6-slot 4WD Wheel Bearing Locknut Tool. Designed for 1978-Current F-Series 3/4 & 1 Ton Trucks and 1973-1981 GM 3/4 & 1 Ton Trucks.
15 Bucks at Advanced Auto Parts!!!
