0 members (),
70
Mod | | | Forums66 Topics128,179 Posts1,057,159 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 7 Apprentice | | Apprentice Joined: Jul 2009 Posts: 7 | I have a factory rear end out of my 1958 chevy truck. I'm wondering if it will (line up) fit and work in a 1950 chevy truck. | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Get your tape measure out and check, but a buddy of mine changed the rearend in his 51 to a later rearend several years ago and didn't have a problem..the truck is still his daily driver...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Jul 2009 Posts: 7 Apprentice | | Apprentice Joined: Jul 2009 Posts: 7 | Thanks Stick for the info. I have the rear end and am selling it to someone who has a 1950, so I can't measure to compare, that's why I was wondering. | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | The width of the '58 will be right for the '50. It will most likely will need the spring pads relocated. If it lines up or not is up to the guy doing the work.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Both are the same width.
The center section from the 58 will bolt right in the 50 housing, if you want to keep the houk brakes. Ether way you will need spring pad work
See the USA in your vintage Chevrolet! My Blog | | |
